Revit 2016 Not Installing
4 REPLIES 4
398 Views, 4 Replies
Dear All,
I really need your help as Revit 2016 keeps on failing to Install,
Whenever there's 11 Minutes remaining and its 6-8 installation are done, the whole prossess gets dissconnected.
I really need the application to be downloaded.
Please Advise.
Thank you.
4 REPLIES 4
Try downoloading it through the virtual agent.
I had a similar issue and that seemed to be the only solution
ennujozlagam
hi, turn off all your anti virus program and you may check it here to download.hope it helps. thanks
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
I'll try doing that... thanks a lot.
Oh dude thank you very much .... it's finally downloaded and working perfectly ... was too excited about it and had to thank you even before going to work !! 😄
Forma Design Contest
