Hi i've seen in the forum many people with the same problem in revit 2017, but not in 2016. I´m having the trouble that every time i make a render, the rendering proces windows pop's up the same message: "The following render appearances images are missing". I tried changing the path in the RSN.INI files, but it was a path of 2017 version, and may be is a different path or log.
If someone had the same problem and can give a helping hand i would be very thankful.
Gelöst! Gehe zur Lösung
Gelöst von -FDC-. Gehe zur Lösung
