Revit (2016) Line Changes Type When it Exceeds a Given Length
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
655 Aufrufe, 10 Antworten
A Revit detail line (Solid #6 width) is solid until it gets longer than 101' 11".  At 102' or longer, it changes to a Center Line Type!  When it is shortened to less than 102' it returns to a solid line.
Any thoughts?
10 ANTWORTEN 10
Nachricht 2 von 11
David_Knight
als Antwort auf: Anonymous
what happens if you change scale?
what line style is applied to that object type?
Is that object being overridden in the view? (vg or template)
i wonder if there is a line type applied, but due to the scale it happens to change to continuous since it is too short for that view?
Nachricht 3 von 11
als Antwort auf: David_Knight
1. It's happening on a site plan, so the scale is 1" = 30'
If scale is changed, same results at different lengths. (At 1" = 40' the line has to be longer to change type, but still does)
2. It's just a detail line.  It's solid, #6 wide.
3. No Overrides or View Templates
Nachricht 4 von 11
David_Knight
go to:
Manage -> Additional Settings -> Line Styles
Expand the window, what is the name of the line pattern used for "#6 wide"
I suspect its not "continuous"
Nachricht 5 von 11
That "solid" Line Style definitely not uses the Continuous line pattern.
Nachricht 6 von 11
"Wide" Lines has a Pattern = Solid
It is #5
Nachricht 7 von 11
David_Knight
is "Wide" the like type you are having issues with?
if so, i would need to see a test file to troubleshoot from here.
Otherwise you can check this too:
Check VG (or your template) under:
Model Categories -> Lines -> make sure that "wide" does not have an override applied.
also, i used the word "continuous" earlier when i should have used solid.  Sorry for any confusion on that.
Nachricht 8 von 11
Line pattern names mean little to nothing.  Edit the Line Pattern definitions and see what the line pattern "solid" defined.
Nachricht 9 von 11
David_Knight
als Antwort auf: ToanDN
Ohhhh yeah. I hadnt worked the problem that far yet.  You're probably right.
Nachricht 10 von 11
The "Wide" #5 line is a Revit standard issue, I created the #6 solid line (along with 5, 4, 3, and 2) for various uses.
It was created, as a new sub-catagory in the Manage > Additional Settings >  Line Styles dialog window.
Someone entered an override in the VG Lines!
AAAARRRGGGHHH
Thank you for your help!
Nachricht 11 von 11
David_Knight
ah ha! i was right!
