Announcements
revit 2016 fails installation on windows 10
I got a new laptop with windows 10 already installed.
I am not able to install revit 2016 or AutoCAD 2016 to the device.
help!
Error message?
Download issue?  User rights issue?
no. I installs but the revit content libraries are missing somehow. Can I browers download on another laptop and transfer to the new laptop and then install? will that work?
Go to Control Panel--> Programs --> Programs and Features
Find Autodesk Revit Content Libraries 2016 and double click....when the splash screen pops up select "Add or Remove Features"
Select the proper libraries, and select OK.  It will download the libraries.
If you want to copy from another computer you can do that too...they reside at:
c:\programdata\Autodesk\RVT 2016
Keep in mind it's 2-3 GB in size.
So.....9 months later after posting this I find out double clicking the Revit Content Libraries 2016 DOES NOT WORK with Windows 10.  Nor does it work with Revit 2017 which is supposed to be Windows 10 compatible.
