So I've been having this issue with Inventor, Autocad, and Revit.
It'll open properly and I would be able to edit files and browse around for about 3-5 minutes then it crashes whether I'm working on something or if it's idling without any projects on and spits out an error
Repairs and steps I've taken:
- Repairing each program individually via control panel.
- Uninstallation and reinstallation (Registry and all.)
- Uninstalled all Autodesk products and reinstalled just Revit 2016
For some reason, neither the templates or families are appearing either and I've tried to repair and changed the file location. The files still didn't show up after the repair.
The connection is steady and I'm above the minimal requirements.
The Error is stated.
- Journal.0022.001.dmp
- dmpuserinfo.xml
- dumpdata.zip
- journal.0022.txt
Thank you
When libraries and templates are missing is usually caused because there were problems with downloading them during installation. HERE is an article on the Autodesk knowledge site with some information and possible solution about it.
When Revit crashes you should look in the latest journal file and see if a cause is mentioned
Louis
Please mention Revit version, especially when uploading Revit files.
according to this. It looks like a memory issue? That was in the end of the journal.
' 0:< Exception occurred
'C 31-Aug-2016 00:37:57.522; 0:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=000007FEED0BAA66
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 1230 / 4095 429=InUse 430=Peak
' 0:< VM Statistics: 8386924 / 8388607 337=InUse 340=Peak
' 0:< unhandledExceptionFilter is executed in a non-main thread (id = 5776, tag = <blank> : [was ]).
' 0:< ::1:: Delta VM: Avail -12 -> 8386909 MB, Used +13 -> 351 MB, Peak +15 -> 356 MB; RAM: Avail +20 -> 1222 MB, Used +3 -> 432 MB, Peak +7 -> 438 MB
' 0:< Got a message. Go to the crash protection!
'C 31-Aug-2016 00:37:58.213; 0:<
' 0:< RAM Statistics: 1222 / 4095 432=InUse 438=Peak
' 0:< VM Statistics: 8386914 / 8388607 348=InUse 356=Peak
Ran the memory test via the computer's own software and all seems to be fine.
None of the Autodesk products I've installed has ever worked properly. They're the student editions, if that means anything.
I've always been missing templates or it would crash. I don't think it's a ram or video problem because I've used this computer to handle some graphic intensive work.
It ran Inventor 2016 fine and would crash once a week, which I could live with. I'm fairly certain Inventor is more memory and graphic intensive than Revit.
This is driving me nuts, and It's causing me to lag on my classwork.
Thanks for the replies, gents.
