1.) Hi i can not download revit content library. But when i intsalled revit It shows that the content library installed.
2.) I can not find family template
hi, just ignore that and go to Big "R" Logo > options > file locations and set your folder templates. please see attached. hope it helps thanks
I tried it but there is no project tamplete in computer. But when i intsalled revit it shows that shows content library installed
do you see anything in C:\Program Data\RVT 2016\Templates\US Imperial?
DarrenP
I would start the installer again, this time uncheck everything except the content library and try another attempt.
Make sure Autodesk.com is not firewalled from your system and just for this shut down the anti virus.
Some solutions work for some but not others. I'm one of the others....
James
There have been numerous posts about Revit content installation failures and a new post has been created to focus our troubleshooting efforts. If you continue to encounter this problem, please refer to this post for the latest details on this issue.
Tony Michniewicz
Autodesk Revit QA
We've recently identified a sporadic issue that will result in content not being installed via the Revit LT 2017 web installer. After our investigation, we found that a required content file is not always included in the extracted files and its absence results in the installation bypassing Revit content files. We are investigating the root cause of this problem and hope to have a resolution in place soon. Until then, the following steps will allow you to work around this issue:
At this point, we've only seen this problem occur with the Revit LT 2017 web installer but based on the numerous reports of Revit content installation problems, a similar problem may impact other Revit versions, including previous releases. For this reason, I've attached zip files that contain the master XML files for each version of Revit 2015, 2016, and 2017. Once the appropriate master XML file is extracted and copied to the appropriate ...\Content\Revit folder, the installation of Revit content should complete successfully.
Realize todo el procedimiento sin embargo me sigue figurando que ya tengo instalado el content library cuando no es asi por favor si pudiera ayudarme
If the template is not present in US Metric file then what to do.......??????
