Revit 2016 changes language from English to Chinese by itself
Message 1 of 64
We are experiencing weird behavior where Revit 2016's interface changes from English to Chinese by itself. Has anyone else experienced this issue, and is there a fix?
Replies (63)
Message 41 of 64
taralis
Just for the record - same problem
Revit 2016 from Building Design Suite Premium on Windows 10
all of a sudden from English to Chinese:
Message 42 of 64
First problem:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
After setting the correct path for the file locations in the options and checking the revit.ini for the correct language settings, and the Revit shortcut for the corret language settings, this happens (all "chinese"):
And when I delete the CHS language folder ( C:\Users\ws2\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2016 ) , it is recreated as soon as Revit is started.
He has installed Revit 2016, R2, Extensions, and Update 4....
Your suggested workaround is not to install R2 ?! come on...
Message 43 of 64
If you fix the family templates path,the language changes.
If you close and open revit it goes back to english but the template path
is wrong again.
The other problem is "preparing to install" that happens now and then.
Message 44 of 64
DavidsDesk
Having the same problem with Revit 2017 deployment.  Thinking of just avoiding the custom Revit.ini
Message 45 of 64
Well, 2017 is basically just 2016 R2 with a few rendering and MEP enhancements.  A fix would have been nice but I can't say I am surprised its not in there.  We are giving them some time to work out bugs before deploying to the office.
Message 46 of 64
dmarchant
I will be stunned (well used to it) again by Autodesk if this issue isnt sorted in 2017~!!
Message 47 of 64
Their priority these days seems to be on rendering and licensing, not fixing bugs.  Thus the reason this is still an issue...even in 2017.
Message 48 of 64
andrew.jefferson
We are still having the same problem! It is so random.
Message 49 of 64
Since I last posted I have upgraded my machine to Windows 10 and activated the Chinese language option on Windows.  I checked the other day and low and behold the problem seems to have fixed itself.  Not sure what did it but my menu options show up correctly and no unwanted Chinese characters.  Go figure.
Message 50 of 64
Hey Giosue, Will this work with Revit 2017? Having the same issue.
Message 51 of 64
we are having this issue on One system - so far. the license is older networked, not a **** desktop. has anyone tried Uninstalled the Revit Language Packs? if so, did it help this issue? Robert
Message 52 of 64
andrew.jefferson
We have fixed this by deleting the 'Revit.ini' file in C:\Users\username\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2016
Message 53 of 64
Deleting or modifying will not help. The problem may seems solved for a
while but it will come back.
Message 54 of 64
andrew.jefferson
It hasn't come back in over a month as of right now. We also only had this happen on our RDS server not any stand alone machines yet.
Message 55 of 64
m.voss.alvine
We had the same issues after installing Revit 2017.  Chinese, cant find path, etc.  The ini files were the issues.  The ini files associated with the deployment were not coping correctly.
check the ini files in these locations.
C:\Users\******\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2017
C:\ProgramData\Autodesk\RVT 2017\UserDataCache
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
Message 56 of 64
DJKell
REINSTALL Revit?  Thats the solution?  That is a collosal waste of my day.  Thanks for nothing.
Message 57 of 64
m.voss.alvine
have you looked at the ini solution above?  It has worked for several people.
Message 58 of 64
Tony_Michniewicz
The immediate cause of this problem is a corrupt Revit.ini file, which you should be able to address by copying a good version of this file to the following locations:
C:\ProgramData\Autodesk\RVT 201X\UserDataCache
C:\Users\<UserName>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 201X
In most cases, this problem stems from the unwanted secondary installer (Configuring Revit 201X dialog), which inadvertently corrupts the Revit.ini file because the original installation media is no longer available and the repair process cannot complete successfully.  Consequently, one way to avoid this problem is to ensure that the original installation media is still available.  However, the drawback of this approach is that users need to sit through the repair process each time it pops up.
The better solution is to eliminate the unwanted secondary installer but the drawback is that this requires Revit to be uninstalled and reinstalled.  In this scenario, the key is to install the available Revit updates first and then the Revit add-ins/add-ons.
Tony Michniewicz
Revit Software QA Analyst
Message 59 of 64
RAMasterson
When you say..."one way to avoid this problem is to ensure that the original installation media is still available", does that include a network deployment on a share that the affected workstation has access to?
I ask because we have had workstations flop to the Chinese language & the share hosting the deployment is valid & available.
Message 60 of 64
Tony_Michniewicz
From the cases I've worked on, being able to access the original installation media (which would include the deployment image from which Revit was originally deployed) is required in order for the repair process to complete successfully.  If this is true in your configuration, the problem may stem from restricted privileges that don't allow the repair process to make the necessary changes.
Tony Michniewicz
