It was working fine 3 days ago when I last used it. This morning its all in Chinese. I saw a post back in 2016. Did Autodesk ever come up with a fix for this issue?
Gelöst! Gehe zur Lösung
Gelöst von Tony_Michniewicz. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
I also had this problem a week ago.
1 You can try to go in the options and change the language there. Unfortunately, that is very difficult because everything is in Chinese.
2 Reinstall here you can then choose the language and it should functunun tun.
3 You can try it with Repar too
With best Regrards
dill
Hi @Anonymous
Welcome to the Autodesk community! Thanks for posting on our forum.
As the first step,
This incident (Revit user interface changes to Chinese) has been resolved in:
See forum thread on similar issue
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
This issue typically occurs when the user's Revit.ini file becomes corrupted and you end up with Chinese because it is the first language in alphabetical order. My initial suggestion would be to delete your copy of the Revit.ini file, which will be located in your C:\Users\<USER_NAME>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2016. This will force a new version of this file to be generated the next time you launch Revit. If this does not resolve the issue, I would recommend posting a copy of the Revit.ini file that resides in your C:\ProgramData\Autodesk\RVT 2016\UserDataCache folder.
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Viveka CD
