Revit 2016 & 2017 Ceiling Grid misalignment
1 ANTWORT 1
Nachricht 1 von 2
569 Aufrufe, 1 Antwort
In Revit 2016 & 2017 is there a way to Align the ceiling grids both in Surface Pattern & the Rendering pattern permanently?
I've tried the texture alignment way but i'm looking for a way that can be set and left without adjusting every time i create a ceiling.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
in addition to texture alignment, try to tick the "link texture transforms" from the texture editor, appearance tab.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
