Hi @Anonymous,
Hope you are well!
Have a look at the following two articles which will guide you through the process:
I hope this helps! ![]()
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
Hi @Anonymous,
Did you purchase your Autodesk Subscription/License from Autodesk or an Autodesk Authorized Reseller?
The quickest route to sort out Subscription/License issues would normally be to contact your Reseller (if you use one) or locate and contact a Local Reseller so that they can assist with subscription and licensing issues.
Autodesk Partner Locator (Just enter your city and hit search).
Rudi Roux
LinkedIn
