Revit 2015- unrecoverable error
4 ANTWORTEN 4
Nachricht 1 von 5
376 Aufrufe, 4 Antworten
Revit LT 2018
file is not save show error encounter a sharing violation while accessing
reinstall software but show same error
4 ANTWORTEN 4
Nachricht 2 von 5
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
Please share a screenshot of your error.
If you recently installed anti-virus, please disable it, it might be that it is blocking Revit from validating its license.
Also, try deleting your temp files.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Nachricht 3 von 5
als Antwort auf: Viveka_CD
PFA
Nachricht 4 von 5
a_meteni
Have you checked this similar case?
Nachricht 5 von 5
als Antwort auf: a_meteni
- Clean your Temp directory (%Temp%). Try to delete most of the files and folders in there.
- Switch off your virus scanner and fire wall and see if that helps.
- Remove your add-ins
- Create a simple project (not shared) and see If you can save that on your local computer
but same error show
please help to resolved issue
