learning to add rail terminations and created a typical pipe railing termination into a wall. when I apply the termination to bottom and top of the railing, the top looks fine but the bottom is backwards. do I need to create a separate termination for the bottom?
I duplicated and then mirrored the original return for one at the top and then one for the bottom of the railing. then after reading some more, it doesn't matter b/c the returns wont show up in plan views.
Thank you.
Hi @htews
I just wanted to follow up here, any progress on this issue?
Please post a file to troubleshoot further if you are still seeking assistance from the community.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
