Revit 2015 Pipe railing termination issue
htews
htews
learning to add rail terminations and created a typical pipe railing termination into a wall.  when I apply the termination to bottom and top of the railing, the top looks fine but the bottom is backwards.  do I need to create a separate termination for the bottom?
It's better sharing your progress file.
htews
I duplicated and then mirrored the original return for one at the top and then one for the bottom of the railing.  then after reading some more, it doesn't matter b/c the returns wont show up in plan views.
Thank you.
Are you sure?  They show up here.
htews
not mine....ghosted in red below
Viveka_CD
Autodesk Support
Autodesk Support
Hi @htews
I just wanted to follow up here, any progress on this issue?
Please post a file to troubleshoot further if you are still seeking assistance from the community.
