Revit 2015 freezes on startup
2 ANTWORTEN 2
Nachricht 1 von 3
351 Aufrufe, 2 Antworten
I recently installed Revit 2015 student version. It was working fine for a while now, but now, when I start the program, it shows the splash screen, then goes to the main menu, and then refuses to respond to any clicks of the mouse, not even on the window controls. The mouse cursor is normal, and the program is not shown to be unresponsive under Task Manager. When I kill it through Task Manager, it shuts down instantly without any hassle. My video card drivers are all up to date. What could be causing this?
2 ANTWORTEN 2
Nachricht 2 von 3
jitu1dange
als Antwort auf: Anonymous
Is your issue resolved?
Have you installed any new plugin in Revit ? That might be the cause, or you can try running repair or reinstall from the add or remove program. All make sure your display adapter is set to your GPU not CPU under your graphics card setting.
I hope this helps.
Nachricht 3 von 3
jitu1dange
I hope this helps.
