Revit 2015 doesnt save
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
594 Aufrufe, 6 Antworten
I Installed Revit 2015 in windows 10 operating system recently. It works fine and the only issue is that the files cannot ba saved. Whenever I tried to save a file it appears as shown in the image attached below.
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello, try to swich off all your anti virus program and firewall and try to save it again. if this works for you. thanks
Nachricht 3 von 7
jitu1dange
Are you working on collaboration with the file? If it is so, then only admin of the project has the right to save the file on computer unless you disassociate the file from the A360 collaboration. But you can certainly save file on A360.
Even if the problem is not fix, try to run repair or reinstall from the add or remove program.
I hope this helps.
Nachricht 4 von 7
jitu1dange
I hope this helps.
Nachricht 5 von 7
als Antwort auf: jitu1dange
It worked...Thanks!!!Smiley (fröhlich)
Nachricht 6 von 7
jitu1dange
You're welcome :leicht_lächelndes_Gesicht:
Nachricht 7 von 7
pleas,by any method
