Revit 2015 & 2018 - Additional Render Apprearance Path
2 ANTWORTEN 2
Nachricht 1 von 3
rodrigo.bezerra
344 Aufrufe, 2 Antworten
Hi fellows,
As mentioned above, I'm having the same issue in both releases: the software can't find the textures in the place I pointed at Rendering > Additional render appearance path.
I saw here that could be a *.ini issue, but seems mine seems correct for me. Following, a glimpse of my 2015 *.ini file (highlighted red)
[Revit.ini]
[Colors]
HiliteColor=12401408
PreHiliteColor=12401408
ErrorColor=33023
CustomColor1=000000
CustomColor2=0000ff
CustomColor3=00ffff
CustomColor4=00ff00
CustomColor5=ffff00
CustomColor6=ff0000
CustomColor7=ff00ff
CustomColor8=ffffff
CustomColor9=ffffff
CustomColor10=ffffff
CustomColor11=ffffff
CustomColor12=ffffff
CustomColor13=ffffff
CustomColor14=ffffff
CustomColor15=ffffff
CustomColor16=ffffff
[Directories]
ProjectPath=C:\Users\RAF\Documents
ImportLineweightsNameDWG=C:\Program Files\Autodesk\Revit Architecture 2015\Data\importlineweights-dwg-default.txt
MaterialLibraryFiles=..\Data\Rendering
IESFileLocation=C:\ProgramData\Autodesk\Navisworks Manage 2015 2015\IES\
RootPathForPointClouds=C:\Users\RAF\Documents\PointClouds
AdditionalRenderAppearancePaths=K:\Biblioteca\Rendering Library\|K:\Biblioteca\Metric Library\Biblioteca_Portobello_BIM\Ceramicas Portobello\
ExternalParameters=K:\Arquivos comuns\Shared Parameters.txt
[DirectoriesENU]
Is it because I pointed 2 paths for each of my different material libraries?
Hope you guys can help.
Regards
Rodrigo Bezerra
2 ANTWORTEN 2
Nachricht 2 von 3
Hi Rodrigo,
Thank you for taking your time to post this on the forum,
So you are not able to see any materials at all? Meaning an exclamation mark at the picture spot?
Best Regards,
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
Nachricht 3 von 3
Hi @Jacob.westergaard, I appreciate your reply.
Am I not able to see any materials at all? No, I can see all the appearance assets locally instaled. It's my network additional places that's returning the error (the exclamation mark you mentioned). Before you ask, no there's no firewall or any network credentials issue that could mess this up.
(Not so) Funny fact: we have a few old 2013 licenses and the Additional render appearance path works just fine, pointing at the same network places.
Kind regards
Rodrigo Bezerra
