Hi there,
I am new to this and really hope someone can help me.
I recently started using Revit 2014 with Windows 10 (via Bootcamp and Mac) and was making some adjustments to my external monitor today and it seems to have completely mess with Revit. First I wasnt able to get into Windows side of Mac, and finally I got in but while my Revit files seems to be be there, they are not functioning correctly.
The files open but when I got to look at floor levels, or views, the whole software seems to stall - , at first it looks like it is trying to do something (there is blinking on bottom of screen) Then it just freezes. I contacted Apple who say that because it is Windows side of my computer there is nothing they can do. I dont know if it is a Windows issue (all other files seem fine but then I only use Windows for Revit) or something with Revit. I tried to uninstall Revit, but nothing happens and is forcing me to say "yes" to a question about making changes to my PC before it will uninstall (sorry I dont have the exact message as I had to force quite to write this). Should I accept yes to this question and try to uninstall? Should I also uninstall all elements related to REvit?
I have save my main work but not some families I made in Revit. I guess I will loose these if I uninstall. Perhaps I should contact Revit support via call.
If anyone has any ideas would be very helpful. I am new to Revit and Bootcamp.
Helen
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
To add, the place at bottom that is "flicking" is the Status Bar, where you normally see "Worksheet" and "Main Model" written in those 2 boxes.
@Anonymous
Flickering and Freezing issues and in most cases related to graphics issue...some solutions which may resolve this issue are:
If the above helps; kindly mark this reply Accept as Solution...KUDOS are also welcomed (only if the above helps)
Suggestion 1 you can Check by going to Control Panel (Windows platform) then to Display ... Here you adjust screen size as well as resolution (latter might be on a different tab)
The use hardware acceleration notice is normal when ur graphic card is not certified by Autodesk. In lots of cases it works even if not certified. But if it continues to cause issues you need to uncheck the box. First do suggestion 1 it is the most crutial and essential to fix first
It's freezing when u uncheck due to screen size and resolution already set...when u fix those it will not freeze. But after u uncheck or check this box u need to close Revit and reopen it.
You don't need to worry about option 3 for now. First try 1, 2, and 4 and if that doesn't work I can assist you further with 3 and other suggestions
Sent from my iPhone
Thank you so much,
That is a relief and such a simple fix when you know how.
I have one other question prehaps you or one of the community might be able to help.
The reason why I got this issue to begin with was my wanting to change the font as it is tiny on my Mac Book Pro. I just bought a monitor last week BENQ GL2450- 24Inch and no matter what settings I try with it, it is no where near as crisp as my MacBook Pro screen. Of course it is smaller screen etc,
It is driving me crazy and I feel like returning it again (I am within remorse).
Can anyone recommend a monitor that works well for revit that doesnt cost an arm and leg? Alternatively is there anyway I can increasse font size and use the MacBookPro with the issues I just got? I was so happy with the bigger font and didnt realise it created the issues I just had.
Thanks again if you have any suggestions, I am happy to buy new monitor or perhaps someone knows good settings to try for this BENQ one.
Helen
@Anonymous
Well that confirms the graphics issues
most probably the testing to make that BENQ work as desired didn't work out weel for Revit.
I would say first finish from the graphix issue on your Mac Book P as you need a working set up first then one can move on to check the other screen. Can't start giving suggestions on the BENQ when we are not curtain the initial/OP was solved!
@Anonymous
Which of the two screens? The laptop's or the BENQ?
It is kinda getting a bit confusing!!! so many topics under one thread..You might want to close this one out by marking the solution and start a new thread for new topic/question when they are not related.
Apologies, the MacBookPro. I am not using the Monitor right now. I will open a new topic for that.
@Anonymous
Thats not a Revit related issue...Does it happen when on Bootcamp/Windows or also on Mac OS? If on windows only maybe you just need to check the laptop's power saving settings.
