We are working in Revit 2012 on a project for legacy reasons. The model is now 161+ megabytes and some lighting & electrical families are not printing when we print at G.A. scale (1:100@A1) If one zooms in & prints "visible portion" they then print so it seems to be a scale issue. Has anybody come across this & if so, does anyone have a nice, simple cure?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Are you printing directly to the printer? I'd suggest printing to PDF first then printing from there.
I'd make a copy of the project and upgrade it to 2018 at least and check to see if that fixes your issue. If it does fix it, then it is a very good reason to dismiss the legacy of keeping it in 2012.
Of course I have some projects stuck in 2015, but we don't have control of that, it is the architects and we are just the interiors.
We do have a couple of cropped sheets on the drawings causing the problem, but the problem occur from views too, so changing that didn't make any difference, although I did try. However, printing as a raster image solves the problem - thank you very much for your assistance.
