Revit 18/19 "checking out"
11 ANTWORTEN 11
Nachricht 1 von 12
htews
471 Aufrufe, 11 Antworten
I have a central model w/ a local file.  is there a way to take the central or local and "check out" to work on it from home?
11 ANTWORTEN 11
Nachricht 2 von 12
Diego.Faria
als Antwort auf: htews
You can always synchronize, open a new detached copy, save it locally, work on it and then replace the file back into your network later on. The problem is that you'll have to make sure no one else works on the file while you have it with you. Otherwise you'll have to copy the differences into a single file or discard one of them.
Diego Faria
LinkedIn
Nachricht 3 von 12
loboarch
Here is a topic from the help on doing this:
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-4E002119-F780-4DFB-AC24-11EF005094D3#GUID-4E00...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 4 von 12
htews
als Antwort auf: loboarch
Now that I detached a project, worked on it.  How do I re-synchronize the detached file?
Nachricht 5 von 12
RobDraw
You're not supposed to detach it. You work on your local copy after making the appropriate worksets editable.
Rob
Nachricht 6 von 12
htews
als Antwort auf: RobDraw
I had to detach the model to work on it at home and now that I am back in the office, need to re-attach it.
I think what i did was Saveas and created a new central model (archiving the previous model JIC)
Nachricht 7 von 12
RobDraw
Why didn't you follow the directions in the link posted by @loboarch?
Is there any chance that someone else worked in it while you were working on it at home?
Rob
Nachricht 8 von 12
als Antwort auf: Diego.Faria
Why is there is an 18 and 19?  If the project is in 2018 and you have 2019 at home...there is no way to save your 2019 project back to 2018...just an FYI.
Nachricht 9 von 12
RobDraw
als Antwort auf: Anonymous
Oops. Good catch.
I totally disregarded that as I read the post. There was no actual mention of versioning.
Rob
Nachricht 10 von 12
htews
"18/19" does refer to the different versions but working in one and saving to another.
Nachricht 11 von 12
RobDraw
Revit only goes one way. Once you upgrade to 2019, you can't go back to 2018.
Rob
Nachricht 12 von 12
htews
I know.  it was for .....nevermind.  Smiley (fröhlich)
