Revit 17.2.2 upgrade does not recognize Stylus BT
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
Sahay_R
827 Aufrufe, 7 Antworten
Our upgrade over the weekend has made Revit see all our Stylus BT families as Arial. Has this happened to anyone else? Is there any solution to manually switching the font over - as I am doing to our template now? What about other in-progress projects that have been affected - how can they be helped in the most expeditious fashion?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
7 ANTWORTEN 7
Nachricht 2 von 8
Viveka_CD
als Antwort auf: Sahay_R
Hi @Sahay_R
Can you check if  Stylus BT resides in your C:\Windows\Fonts\ folder?
Nachricht 3 von 8
Sahay_R
als Antwort auf: Viveka_CD
We have STylus BT Light. I think that is what shows up as Stylus BT under Properties.
All team members would have a similar set up on their machines. The issue surfaced after the upgrade was installed over the weekend.
Rina Sahay
Nachricht 4 von 8
Viveka_CD
Hi @Sahay_R
I checked this issue in Revit 2017 and the stylus font works fine, and I am able to edit the font to Stylus and it does not substitute to an Arial font.
We have similar reports regarding font substitution for missing fonts in Revit
  • Did you publish a DWF from Revit Architecture - if so, HERE is a similar discussion
  • Is this file a linked model?
  • Also, Did you do windows upgrade and which version of windows are you using? Is this specific to all users/ machine and other Revit versions?
  • Were you trying to print to PDF? Screenshots or a screencast would let us know how and when this happens.
  • Can you share a screencast and the font style if possible? It will help to investigate this issue with the development team.
Please see screenshot below for reference:
Nachricht 5 von 8
Viveka_CD
Hi @Sahay_R
I just wanted to follow up here, any progress on this issue?
Nachricht 6 von 8
Sahay_R
I'm afraid that I changed all the families around before I got your request! So sorry!
Rina Sahay
Nachricht 7 von 8
Viveka_CD
Hi @Sahay_R
Do you still have the font substitution issue? Can you check this for me in a new project on your machine?
Nachricht 8 von 8
Sahay_R
Hi @Viveka_CD - I got into the template and changed all the fonts over from Stylus and IT reinstalled the font in our Fonts folder. SO we are fine now!
Rina Sahay
