I see you can now add a prefix for revisions which is great. But is there a way to change the prefix halfway through the revisions?. To British standard BS1192 revisions go P1, P2 etc for pre contract, then when the drawing is contract the revision sequence changes to C1, C2 etc.
Yes Revit 2016 now allows you to include a profix such as P, C or any other prefix you might wish to use. However; the prefix is applied to all sheets in the model; Hence, it would only really works if you have a clean break between pre-construction, construction and post construction. Otherwise the pre 2016 method of manualy adding a Prefix entery in the sheet numbering that reflect phase is still more convient more convinient
I have now found a way to do it properly to BS1192. When the P1, P2 ETC changes to C1, C2 etc I use numeric for the P1 stage then use Alphanumeric for the C1 stage (as the you change what you want to appear in the sequence)
