Revisions and 3d model
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
nancywelc.ms071.9.90
188 Aufrufe, 1 Antwort
hello i need to know if i make revision cloud in the plan view and change one or two element (example - i delete a bearing wall as required by the client) ... so i want this to show in the revision schedule so i do it as a revision
then what will happen with the 3D model? the wall will be remove in the model or it will not changed?
since the view is linked to the 3D model right?
thank u.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: nancywelc.ms071.9.90
Yes. Changes you made to the model on the floor plan will show on any other views (ed, elevation, section....).
