Hello, is there a method of setting up the revision schedule where a triangle is automatically placed around the the number in the titleblock without having to draw a rectangle manually around each number (not in the view, already have that, but in the title block.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
No. You would have to place Delta symbols manually on the Revision schedule on sheets.
