Revision Sequence access in sheet index
2 ANTWORTEN 2
Nachricht 1 von 3
KMillerVGJK4
514 Aufrufe, 2 Antworten
Why don't we have access to the revision sequence parameter in Revit Sheet List.
Most every Architectural firm I have worked for, we would love to track revision history on our sheet index.
If this is something Revit can do, I would love for someone to help me out with this. I have searched all over and can't find a real solution; therefore, I figure I would make a request for this feature.
thanks,
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: KMillerVGJK4
We can report that info on a Sheet List, albeit not in that format.  Is that what you are talking about? The format?
Nachricht 3 von 3
RDAOU
What do you mean by having access to the Revision sequence parameter?
In principle you have access to it in the revision schedule families directly or indirectly if you use the revision schedule families and place them on your sheets...Alternatively you can use Dynamo to extract the information from the Rev Seq parameter and use it wherever you want...
