Hello All,
I am working on a Revision Schedule that will be placed only on the title page for a project. This schedule will be more detailed then the schedule that is located in the Ribbon. (The ribbon will show tag, title, & date - Detailed schedule will have full description and whether its issued). I am using Revit 2020, and have made the schedule, however when I go to try to use it only one of the Revision show up - even when I try to itemize every instance. I have tried to toggle multiple different filters, etc. with no luck. I have attached an image of the two schedules on the sheet - on the right you can see the built in titleblock schedule that shows the different revisions, on the left is the detailed schedule which is only showing a blank line and revision #7.
Any suggestions would be much appreciated.
Thanks!
Trevor
The revisions have been checked on for the sheet, and they still are not showing up in the schedule on the cover page, only on the right side bar schedule.
It appears to be only showing the most recent revision on the schedule, and overwriting the prior revisions.
