Revision schedule
Revision schedule
Message 1 of 9
Revision schedule
I want to know how can I use different type of numbering in two revision schedule (use numeric in one and alphabet in other)please?Capture.PNG
Replies (8)
Message 2 of 9
Do you have any unused field in Revisions settings?
Message 3 of 9
I have 2 companies related to my project and I want to separate the revision schedule for 2 tables and make one of these numerical sequence for the revision numbering and the other half of table alphabetical numbering
Message 4 of 9
I got that from your initial post.  What about answering the question above?
Message 5 of 9
I don't understand what fields do you mean please?
Message 6 of 9
If one of the fields below is not being used then I may have a workaround for you.
Message 7 of 9
These fields not empty, thanks for your time
Message 8 of 9
syman2000
I've set up where I use shared generic annotation embedded inside the titleblock to get the two revision schedue. One of them will be control by generic annotation which you can link with the global parameter while the other is revision schedule.
Message 9 of 9
That is unfortunate.
