Dear Revit Masters,
Here's my problem: I set up the line style and line weight carefully in my project, but it turned out the line weight of the REVISION SCHEDULE is thicker than other lines in the TITLEBLOCK. (image 1).
Both the Title Block and the Revision Schedule are using the same line (image 2 & 3), which is "Medium Line" I defined, using "Line Style 4" at 0.9mm weight (image 4 & 5).
Many thanks in advanced.
Harry
2
3
4
5
yes, my question is :
How to unify the line weight between the revision schedule and the other lines used in the title block?
According to the setting, they should be exactly the same.
Normally the revision schedule is part of the title block. Are there not settings in the family's Object Styles that are controlling that?
I have had the same problem for years, and it surprises me that I'm not finding more online converation about this. My experience is that the Outline in a Schedule (set in the Appearance tab of Schedule Properties) is off from detail lines, either drawn in the sheet itself, or within legends on the same sheet as the schedule. I like to have the graphics on the sheet pop, so I use something in the range of width 5 - 7. It appears that a corresponding detail line is at least 1 width thicker to match. Why?
The improvements made to schedule graphics since this original post are probably numerous, but each time, it is a very limited attempt to throw us a crumb one at a time, such as striped rows, having a column to show images for scheduled components (which I have tried and found to be not worth the trouble), and giving us control over the height of rows and even formatting the title text more easily.
It would be nice for the factory to finally give us a robust Excell-ish upgrade to schedules, as they are so powerful at the data end, but not graphically, despite the long list of minor features added.
This, however, should be classified as a glitch, a bug, or at minimum, an illogical inconsistency.
I have the exact same issue... and it's anoying because it doesnt make sense!
I'm glad to see it's probably a bug.
I'll create another line type as a work around for this problem.
thanks for sharing ![]()
