Revision schedule directly in project
2 ANTWORTEN 2
Nachricht 1 von 3
FGPerraudin
242 Aufrufe, 2 Antworten
Hi everyone,
Does anyone know of a way to create a revision schedule directly in the project?
As for now, I create a titleblock family with only the revision scedule in it, but I would like to be able to interact with it straight from the project...
And I have to go through a sheet and check every revision in the "Revisions on sheet" options by hand for them to exist in the table!
It does the job, but would there be a better way?
Thanks in adavnce for your input,
François
Francois-Gabriel Perraudin
BIM management and coaching
2 ANTWORTEN 2
Nachricht 2 von 3
devonpowell
als Antwort auf: FGPerraudin
In short, I don't think there is a better way...
You could create a key schedule with dummy parameters and use the API to populate the key schedule with the revision information using the Revision class. Definitely a workaround, and not any easier or straightforward than your method. You could also create a sheet index showing the "Current Revision" and create one dummy sheet for each revision.
To quickly apply a revision to many sheets I've used Xrev Freebies add-in which works pretty well.
https://www.xrev.com.au/products/Xrev-Freebies
Nachricht 3 von 3
FGPerraudin
als Antwort auf: devonpowell
thx @devonpowell, just wanted to be sure there wasn't an integrated solution....
I will programm an addin about it I think....
Cheers!
