Revision schedule column question
3 ANTWORTEN 3
Nachricht 1 von 4
vanessaH6CHC
263 Aufrufe, 3 Antworten
Does Revit give you the ability to put revision schedules into 3 consecutive columns? Attached is a screenshot with the columns i want to use.
3 ANTWORTEN 3
Nachricht 2 von 4
rxi.gg
als Antwort auf: vanessaH6CHC
You can choose how many revisions you can show (for example the last 10) but you cant cut the schedule
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 4
hmunsell
what is the purpose of the 2 additional columns?
With Revision Schedules your restricted to the out or the box parameters. You can't make additional parameters or add Shared Parameters to use. You can select the "Select Available Parameters" drop down and pick Project Information and utilize those parameters, but nothing that will be revision specific.
Howard Munsell
Nachricht 4 von 4
vanessaH6CHC
We often have more revisions than just one column for certain sheets and its how my company has done it in the past when we use horizontal borders.
Thanks both of you for your answers. Its unfortunate that Revit doesn't have a solution for this yet. Ill add it to the suggestions forum.
