revision number
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
BIM_Dreamer
509 Aufrufe, 7 Antworten
revision number
first time issue drawing site plan and 1st storey plan, but my problem is the issue number per sheet? it should be 1 in site plan and 1 in 1st storey plan but my 1st storey plan become revision 2, how can i make them as rev 1 in per sheet. any help is much appreciatedt.thanks
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: BIM_Dreamer
Are you sure there is no other revision on that sheet?
Nachricht 3 von 8
BIM_Dreamer
als Antwort auf: ToanDN
Yes,  first time issue and rev number should be 1 with different annotations per sheeet,  my 2nd sheet become rev 2 instead of  rev.  1. To make rev 1
Nachricht 4 von 8
Sequence 28 and 29.
Nachricht 5 von 8
RSomppi
Post your revision dialog box.
Nachricht 6 von 8
Open the sheet, click the box Revisions on sheet from properties and show what you see.
Nachricht 7 von 8
BIM_Dreamer
i solved it. it just the cloud are not in the same sequence. thank you for your help.
Nachricht 8 von 8
I pointed that out yesterday.  Message 4.
