Revision Cloud
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
ikocev
746 Aufrufe, 3 Antworten
Revision Cloud
I am trying to find a way to change / uncheck the grayed out box ( see attached ) so I can change the wrong revision number which happen to be "11" instead of 1 ...
Thank you very much.
3 ANTWORTEN 3
Nachricht 2 von 4
MostafaElashmawy
als Antwort auf: ikocev
This revision number are auto-numbered.
You can change the method of numbering or the starting number by clicking on numeric or alphanumeric.
Mostafa Elashmawy
Nachricht 3 von 4
Lakshman01
als Antwort auf: MostafaElashmawy
Hi @ikocev
You have an option called  customize the numbering on your right side Numbering. For sequence starting number there you can give 0 or an integer greater than 0.
For more please view the image.
Nachricht 4 von 4
ikocev
als Antwort auf: Lakshman01
Thank you guys, I was in a hurry that even didn't notice that option. Cheers.
