Revision Cloud Size
Revision Cloud Size
waleedt
Revision Cloud Size
waleedt
Hi All,
I need to use different revision cloud sizes in the same project. Meaning I need to have at lest 2 different clouds with different arc lengths. unfortunately I have tried manually draw the cloud lines but it takes A LOT of time!
Please help if you have encountered similar issue and know a solution.
Thanks in advance.
RLY_15
Unfortunately, the only thing that comes to mind is the same solution for having revision clouds without the uneven arcing - do it post-production in a PDF editor.
If that isn't an option, perhaps use color identification on your revision clouds instead of arc length?
Basam.Yousif
As you have found out, Revit does not allow for that. Graphic Filters can't help you there either.
Instead, you may have to make separate sheets for each revision, or just override graphics by element - you have control over line pattern, color and weight. You can also use different sketch 'shapes' maybe?
