First time ever encountering this. I have a callout view of a floor plan. There's nothing special going on in terms of view templates, view range, visibility settings, and its dependency is independent. There are no plan regions, design options, etc. Very standard view. Revision settings are per sheet.
When I make a small revision cloud, everything is fine and the cloud has a number.
However, when I try to make the cloud a little larger, there is no longer a number. The Revision number parameter is empty for the cloud. And yes the revision is still set to the same revision. The cloud is still within the bounds of the view and again there are no obstacles or settings going against it. Why is this happening?
