Revision bottom right of my title block isn't changing with my revision on sheet
2 ANTWORTEN 2
Nachricht 1 von 3
c.bennett
724 Aufrufe, 2 Antworten
Currently the Revision no. on the bottom right of my title block family is changing throughout the project and isn't corresponding to the revision of what the sheet needs to be.
I can change the rev of the sheet fine using View/Revisions and then in Instance Properties add a Rev to a sheet but need the bottom right rev on title block to change with it.
This is same with my drawing number changing through the whole project. An un-editable Drawing Status as it doesn't have an option in Identity Data for me to change the Status per sheet.
Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: c.bennett
What Shared Parameter is the Label using?
Nachricht 3 von 3
Is it supposed to be the Current Revision of the sheet?
