Revised mullion profile to show a joint on one side. Having issue when mullions meet at corner, the joint is discontinued. Anyway can make it (joint) continuous at corner, like the red line shown in elevation view?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Curtain Mullions do not Mitter Join in elevation if that is what you are after, model it as a Window Family. If you intend to make a subframe, then nest 2 curtain walls into one another...Otherwise
Alternative,
