Pretty sure that the answer to that is no. The middle mouse wheel will only allow you to zoom in and out.
Another no -= Revit does not match Inventor in any way, it's a completely different program.
You can add another wheel on top the the existing wheel and use it with Revit.
Or, turn the mouse 180 degree, and swap the left right click function in Windows mouse setting (left handed).
Hi @Anonymous
Welcome to the Autodesk community!
The following app maybe worth a try -
WizMouse is a free utility that can be used to customize mouse behavior. The utility's main function is to enable the mouse wheel for applications that do not natively support its use. There is also a handy "reverse" function for use in those situations where the mouse scrolling is backwards. WizMouse can be enabled or disabled from the system tray.
You can also submit a feature request by visiting our Ideas forum
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
