I need a reveal to wrap around 3 sides of a wall.
I have read this is possible by creating reveals on 2 sides of the wall and modifying the returns.
Once I select one of my reveals and use to modify returns command, I am unable to select the other reveal (I have tried tabbing).
Also I am unable to create both of these reveals in the same action.. I have to make one, then exit the command and create the second one separately. I am only unable to create two reveals in the same command when those reveals are on opposite sides of the same wall.
Maybe this has something to do with my issue?
Are you trying to wrap the wall ends with a reveal? You can't in this manner. A solution would be to create a wall segment mitered at the corner. The length of the wall segment would be equal to the wall's thickness. The idea is to create a wall face at the corner to which you can attach the "return" reveal. But making a 180 degree turn would be a little trickier - but not improbable.
