Reusing modeled in place components?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
vanderloo5
130 Aufrufe, 2 Antworten
I created a wall sweep to use as corner trim on my residential Elevations but every time I try to apply it to a different corner I have to create a new sweep.
What's the easiest way to re-use a wall sweep corner profile repeatedly without having to rename or recreate it?
2 ANTWORTEN 2
Nachricht 2 von 3
SteveKStafford
als Antwort auf: vanderloo5
Are you using the Wall Sweep tool or Model-in-place and then creating a sweep? The Wall Sweep tool uses a profile family you assign to the wall sweep type. Then you can place the sweep along a wall or connected walls. Model-in-place is not intended to manage repetition, they are meant for "one-off' situations.
Steve Stafford
Nachricht 3 von 3
vanderloo5
als Antwort auf: SteveKStafford
I am now using a wall sweep however it's a little particular about what corners it will and won't work on. Modeling 2x4 corner trim. Ended up having to use filled regions on the ones that would not work.
