Hello All,
Is there a way to accomplish the following?
I've some filters based on Parametric values for the model elements. And I use them to set colour overrides in Revit. While exporting NWC from the view, the colours are not retained.
The difficult way is to create search sets based on the same parameters in Navisworks and apply Colour Overrides there. But that is a lot of work and redoing.
Thanks in advance. @RDAOU
Solved by RDAOU. Go to Solution.
Thanks in advance for what!!?? Who said I have a solution for this question ??? 😛
Well... to my knowledge colors overrides applied using filters in Revit will not transfer to Naviswork when you export as NWC (which ofcourse you have noticed already lol)...However, there are a couple of workarounds.
When will this feature be implemented? This is common amongst everyone I talk to in the industry.
We need to be able to add color to MEP fabrication parts that by system that transfer to NWC. That or filters which can be added to the REVIT side and get exported to NWC.
Apperance profiler and sets are glitchy and puts the issue on the model compiler.
Please!
