Results of a "section from view" and "section box" are different
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
325 Aufrufe, 2 Antworten
Hi all! Was wondering if anyone knows the solution to the aforementioned problem? As attached is an image for reference too.
For context, the model in the scene is a linked exported SAT model from a colleague who is working in Rhino. Thank you so much in advance!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
You can check if Imported objects are set to show in the view.  It could also be that the detail level needs to be set to fine.
Nachricht 3 von 3
Oh my goodness this worked perfectly, thank you so much!
