Restore Level +1 to zero
5 ANTWORTEN 5
Nachricht 1 von 6
370 Aufrufe, 5 Antworten
Dear all,
Does anyone know how to least painfully move the whole project to 0.00m ? Someone accidentally moved the whole project upwards. Display is set to Project Base Point.
5 ANTWORTEN 5
Nachricht 2 von 6
Karol_Piroska
als Antwort auf: Anonymous
most likely someone used "transfer project standards" including site settings. In your view (plan, section or 3D) enable site elements and project base point. Then select the project base point and change the elevation value
Nachricht 3 von 6
In an elevation or section view, Relocate Project and move it down 490.44m.
Nachricht 4 von 6
unfortunately none works...
Nachricht 5 von 6
You sure someone didn't move the Project Base Point instead? Seems unlikely the whole project could get moved accidentally.  Fix by moving the Project Base Point up 486.36m.
Nachricht 6 von 6
Unclip the project base point and move it upward 436.36 m.  Then re-clip it.
