Hello all,
When I print in pdf the texts are bigger than in the project. I read that it is a revolution issue, but what I need to check? In the image below are the dispay setting of my pc. Is it something that I need to check in Revit?
Thank you in advance!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
The answer was here :
Log out and log back in to Windows to apply the changes.
Thank you!
