reporting parameter
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
kboschJGDNZ
1597 Aufrufe, 1 Antwort
reporting parameter
Hello I want to use the outcome of a reporting parameter in a formula, but I keep getting error messages saying that a reporting parameter can be used in a formula only if it's dimension references are all to host elements in a family. I do not understand what that means. The following screenshot shows an in family screenshot of a reporting parameter hosted to a simple circle. In my opinion it is hosted to an element in a family...so why doesn't this work?
1 ANTWORT 1
Nachricht 2 von 2
pieter1
als Antwort auf: kboschJGDNZ
Reporting parameters will only work in formulas when they are referring to a condition of the host. For example: a reporting parameter that tells you the wall thickness of a wall-hosted family. It seems like you are using a non-hosted family, so I don't think you will be able to use any reporting parameters in formulas.
