Report in Schedule/Quantities which family parameter I checked
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
469 Aufrufe, 4 Antworten
I have created a family with inside various Yes/no parameter, and I want to ask if it is possible to report in the schedule (Image) which parameter i have selected. (for example one Fondation will have a beam HEM240, another one HEB200 and so on...)
4 ANTWORTEN 4
Nachricht 2 von 5
Ilic.Andrej
als Antwort auf: Anonymous
Those yes/no parameters need to be shared parameters. Shared parameters are available in schedules. Then, you need to convert yes/no values to text values by creating a calculated parameter and assigning this formula:
if(HEB200,
    "HEB200",
    if(HEB220,
        "HEB220",
        if(HEB240,
            "HEB240",
            if(HEB260,
                "HEB260",
                if(HEM240,
                    "HEM240",
The condensed formula (copy it to Revit):
if(HEB200,"HEB200",if(HEB220,"HEB220",if(HEB240,"HEB240",if(HEB260,"HEB260",if(HEM240,"HEM240"," ")))))
If you don't know about shared params, I ll make you a screencast.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 5
als Antwort auf: Ilic.Andrej
thank you...but I didn't catch the work behind those shared parameters..never used them, if you can do a screencast would be great
Nachricht 4 von 5
Ilic.Andrej
Andrej Ilić
MSc Arch
Nachricht 5 von 5
yes, very clear
thank you very much again
