Lets say you want to remove an existing door or window and replace it with a new one in the exact same location - this only seems to be possible by drawing temporary lines to mark where the existing door/window was and therefore give you a line to place the new door/window on. Why cant there be a demolish and replace tool so that your old door shows dotted on your demolition drawing and your new door is in the same location ie in the opening you have left. Seems like an obvious thing to me??
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von dave_perkin. Gehe zur Lösung
@dave_perkin wrote:Lets say you want to remove an existing door or window and replace it with a new one in the exact same location - this only seems to be possible by drawing temporary lines to mark where the existing door/window was and therefore give you a line to place the new door/window on. Why cant there be a demolish and replace tool so that your old door shows dotted on your demolition drawing and your new door is in the same location ie in the opening you have left. Seems like an obvious thing to me??
It is a simple task and does not really require a new option
Nothing there to complain about
After you paste aligned >>> Change its type to which ever type you have loaded...Single/Double/Sliding
Thanks - yes I realised this was where you were going with it. Soloution works I just think its a bit long winded and could be simplified with a new function. Thanks for your help#
David
Long winded?
How do you think it could be faster?
simply by you not inserting yourself into a thread that was already solved would surely make things faster.
I came here to see the solution.
Go take a flying leap you hypocrite.
That's a great idea. Did you know there's a forum for that?
This is how we've been doing it, but all I'm getting in this project is "Instance(s) of 620x690 not cutting anything."
(That's a window in this version.)
Pasting to the same place isn't working. Sometimes we can't even create a new window anywhere on the same wall without that error. I had to delete the first one that did work before it would let me create any others.
I've been pasting it to the side and sliding it into position. If I go all the way there I get the 'not cutting' error.
When I'm nearly there, I can use the 'select primary host' button, and select the phased infill. Then move the window into position. But that doesn't always work either.
Any ideas why it's not working in the first place? The original came from a surveying company and then via another architects, but not sure how you can mess up inserting an existing window.
My blog post might address what is happening with your windows if they use a void to cut the host wall instead of an opening. When a family uses a void it causes strange errors or warnings when doing window or door replacement and the replacement is the same size as the original.
As for the OP (which is an old question)... in my case I find I rarely need to put another door back in the same spot so workflow optimization for window or door replacement is probably too niche (for me at least) to attract the development team's attention but it might be interesting to a 3rd party developer?
Steve Stafford
Thanks @SteveKStafford.
I've had a look and yes the family has a void or two. (Read the blog thanks.)
We were replacing the demolished family with the same family and planning on changing the type later.
What was odd is that after the first replacement worked, we couldn't insert any window anywhere on that wall. Expanding the error highlighted the first replacement window, so it didn't like how that was installed. I deleted and redid that one and we got a step further.
The way I've solved it is to place the new window somewhere else on the wall and slide it along till I get the 'not cutting' error. Then switching to a 3D view, use the select new host and select the phased wall infill. I can then move the new window over the old.
I've not tried the void vs opening family switch yet. Someone else in the office is following behind me once I've got the phased window correct.
Cheers
Any families placed in the wall are vulnerable to future editing when families using a void are present. If you alter the length of the wall, edit the profile, change the base or top constraint, and/or add a window/door you may find Revit generating a warning that "elements will be deleted". At this time, it seems, the only way to avoid that vulnerability is to use families with openings instead of voids. That assumes doing replacement work, replacing existing with new elements that are the same size or very nearly the same size and same location.
Steve Stafford
Already replied to this...earlier, nevermind...
Steve Stafford
