Repeating detail snaps
6 ANTWORTEN 6
Nachricht 1 von 7
emmanuelbee
1317 Aufrufe, 6 Antworten
Is there any way of being able to snap to a repeating detail component? you can snap to a standard detail component but snaps don't work with repeating details. is there any way around this?
6 ANTWORTEN 6
Nachricht 2 von 7
kadmonkee
als Antwort auf: emmanuelbee
have you tried applying a DETAIL group consisting of reference planes?
I set the origin to the bottom right corner this allows for ease of moving and snapping
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 7
emmanuelbee
als Antwort auf: kadmonkee
I'm talking about about being able dimension the coarses in block work etc. see attached, as a repeating detail you can't snap to them
Nachricht 4 von 7
kadmonkee
My apologies for the confusion
not sure why you are not able to accomplish this
I created this test and was able to snap to my detail components using aligned Dimensions
check the detail component family to see how it was created.
is the detail component made of individual components or grouped?
maybe settings in your view are set differently?
this worked in both a live model view and a drafting view
thank you
Nachricht 5 von 7
emmanuelbee
is that a repeating detail component? or are they just single detail components that you've stacked on top of one another
Nachricht 6 von 7
kadmonkee
single component stacked
I now understand your dilemma
my ignorance is showing I thought it would be something as simple as that.
I tried all options in the Edit type with the same result
it only provides a start and end grip to snap a dimension to
thank you
Nachricht 7 von 7
JJWGallagher
I tried adding reference planes to the family repeating and it doesn't work. I don't think there is a way to do it. You could draw a small line and array it, but if you're doing that you might as well just array your single detail component.
EDIT: If it is just for blocks/bricks, we dimension the entire thing and add a prefix in the dimension string "X brick ="
