Repeating detail component invisible in printed output
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
ajrinconV56U7
151 Aufrufe, 1 Antwort
So, after using depth cueing in a section, the repeating detail components aren't appearing in the printed output. They're visible in the digital view but don't show up when printed. I've checked everything, and this issue only arises when depth cueing is activated. Any idea of how to fix this?
1 ANTWORT 1
Nachricht 2 von 2
ennujozlagam
als Antwort auf: ajrinconV56U7
have you try to install latest updates from autodesk and see if helps?
