rendering
6 ANTWORTEN 6
Nachricht 1 von 7
inzzre
344 Aufrufe, 6 Antworten
rendering
the render tab on my 2017 revit LT only offer cloud rendering, where is my render (my own device) tab?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: inzzre
Hi there.
Are you in a 3D view? Because when we`re on a plan, section or elevation view, we can`t render it. It only shows the Render in Cloud option.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
Nachricht 3 von 7
inzzre
als Antwort auf: Anonymous
thanks but my actual tab is actually missing _ only cloud render available?
Nachricht 4 von 7
dgorsman
I think that's a limitation of the "LT" product.  Have you checked the product page?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Nachricht 5 von 7
inzzre
and this is from my revit2017 LT subscribed copy  r1.PNG as you see my render tab to allow rendering on my own PC isn't there. did my copy only allows for online rendering or did I miss a download
Nachricht 6 von 7
inzzre
als Antwort auf: dgorsman
thanks i'm checking my account now to see the limitations. Thanks
Nachricht 7 von 7
loboarch
It is not possible to render on the local PC with Revit LT. render in the cloud is the only option. If you want to render locally you need to have "full" Revit.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
