hello my name is zaki from srilanka i am glad to using autodesk products.i am using revit LT i have some doubts in there. how can i get render option, i tried so many times but its not appear i am kindly requsting how can i get that. thank you
Gelöst! Gehe zur Lösung
Gelöst von FAZIOGREG. Gehe zur Lösung
If you are a student, Autodesk allows you to download the full version with something like a 3 year license. Just google "autodesk student".
If you are a beginner and using Revit LT, I highly recommend checking out the following Revit rendering tutorial because it will save you hours of trial and error in the Autodesk Rendering process. The exterior and interior rendering in Revit is one of the most fundamental reasons that the architectural community initially moved to 3D graphics. RCome learn how to do rendering in Revit using Autodesk Revit Architecture and take your 3D graphics to the next level.
This Revit tutorial will show you step-by-step how to complete an Autodesk 360 rendering in a few user-friendly directions . Make sure you subscribe to Smarter Architect for additional tips, tricks, and tutorials if you find the video instruction to be helpful. We guarantee you will! aAt a minimum, my tip for the Smarter Architect community is "use this revit rendering process for all your draft rendering views and then select only a few final renderings for in-product Revit rendering even if you utilize the full Revit suite vs LT.
