hello guys, i almost complete my project, then i want to try render it, but it got 5 gb ![]()
why it is so big just for 1 image?
if i use the Screen option, the pixel will get too low, and the image result were so bad.
it is normal ?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
Try changing the render resolution DPI
Try changing the scale of the view too 1/50 instead 1/10 which shows in your screenshot
You can also try rendering using Lumion or Enscape (much better results)
Check other option on the following link
